Work Geometry visibility
I would like an extra option for all work geometry: It should be possible to create new work geometry and set it to Invisible automatically after cereation. After all, you can select it in the browser if you need it. And that option would save you the extra work to disable its visibility in each instance where you use it as a component in an assembly.
1 Comment
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
