In the sketch environment it's not possible to drag a window over some points and project these at once. Now when using the Project Geometry you can only project one line or point at a time.
It would be great if a window selection could be used to select multiple lines and/or points to project in the current sketch. This would save a lot of time if I have to project points from an assembly sketch in a part sketch, for example.
