I use excel variables heavily. When I copy a sketch I want the copy to be a true copy. But instead the copy uses references to the model parameters in my original sketch. It should copy the formulas that reference my Excel variables.
If I want to delete my original sketch and keep the copy then the referenced parameters are now orphaned.
I have to pains-takingly edit every dimension in every copied sketch to match the original.
See Attached
1) Create a spreadsheet with two parameters Length1 and Width1
2) Create a part and link to the spreadsheet.
3) Create Sketch1 with a rectangle that is Length1 x Width1. Save and extrude the sketch.
4) Copy Sketch1 to become Sketch2. Sketch2 should also have a rectangle of dimensions Length1 x Width1 but instead has dimensions d6 x d7 which mean nothing to me.
AutoDesk Please Change this behaviour so that my copy matches my original.
Example - Copy Sketch.zip
