i want to see a better thing to switch visibilty of any kind of geometry.
It´s horrible first to set a selection filter for choosing some visible objects, then RMB find the visibility entry to switch it off. And it´s very horrible to find the invisble geomtry in browser select it and another RMB find the visibilty entry an sitch it on. This is procedure which is done hundred times an hour. So this has to be much more userfriendly.
So maybe this can be done like in Alias. I don´t have to choose a lecetion filter first, i can select everything with window selection und hide it with a shortcut. Other way around. I can switch the window so that i can see only the invisible geometry where i can also select with a window and switch them visible with shortcut and end up with a window switch to the visble environment. This is a very fast way of switching visibility!!!
Michael
