View orientation
View orientation
Please make it possible to change the orientation of your base view after it has been placed. Because now if I place my view in the wrong orientation, I have to delete the view and add it again. This is a major pain and there is no reason for it.
11 Comments
Click here to change your drawing view orientation:
JimmyDoe
I usually use that option when placing an isometric view. But for changing view orientation, of a standard view(left, right, front, back...) after it is placed, why not just have the option of picking the orientations listed, instead of greying them out? Using the method you're showing still involves going back to the model view, changing the orientation using the view cube and then going back to the drawing. Multiple steps that shouldn't be required and just burn time.
Not sure.  Just another one of the things that I've had to learn to live with, with Inventor...
JBerns
View Orientation is now easier to select and change in Inventor 2016.
Pick a face on the ViewCube during creation or view editing. If you need something other than an orthographic or isometric, right-click the ViewCube and select the Custom option.
I hope this information has been helpful.
Jerry
JimmyDoe
Ok, so you can change the view orientation of your view after it is placed, without going back to the model? The options will not be greyed out anymore?
JBerns
Correct. Notice the Edit View dialog box in the image. The view selection options have been removed from the dialog and the ViewCube now controls the view orientation during placement and editing.
While editing a view you can also add a projected view. Even easier to create a drawing from the model. All great documentation enhancements in Inventor 2016.
Jerry
JimmyDoe
Ok, that looks great 🙂 Do you know when the suscription update for 2016 will come out?
"Ok, that looks great :smileyhappy:Do you know when the suscription update for 2016 will come out?"
It's already out.  If you don't have the new serial number, you can contact your reseller for it.
JBerns
It depends upon what suite you have. Product Design Suite is available now. I believe Factory Design Suite should release soon. Log into accounts.autodesk.com to  check the download and get your serial number.
Jerry
DRoam
This Idea could be marked as Implemented. (@dan_szymanski,  @Discussion_Admin)
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
