User Defined View Scale list
Allow the user to define the default list of available view scales for an IDW view.
The existing list is short. Sure, I can type one in, but that costs me time.
It would serve the user better to allow him to define the default scales he uses and populate the list with those thereby shortening the time it takes to get down to business in the drawing. Classify it as a better user experience.
4 Comments
This is already possible to do using the Style and Standard Editor in your idw template.
Open your idw template file (typicaly C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\Standard.idw)
In the manage ribbon select Styles Editor
In the list on the left select the active standard
In the section "Preset Values" select "Scale" in the dropdown list and set the list of scales you would like
Click "Save" and "Done"
Just do not forget to save you drawing template after modifying the style.
Does THAT classify as a better user experience? 😉
Well, thanks Pierre Berube. It does indeed.
I've been away from creating drawing standards so long that I totally overlooked the obvious.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
