Use a default subfolder in inventor ipj for cc files
Possibility to use a default subfolder in inventor project for contant center files.
If user wants to save the standartparts to the project, he hast to change it for every project.
2 Comments
jtylerbc
There is a way to work around this with existing features, which may help you out.  You can make one project file that is already set up to point to the subfolder the way you want it, and then just copy and rename it to start new projects.
This gets you around the need to set it for every project individually (and prevents the problem of sometimes forgetting to do so).
thx for your suggestion. I know this workaround, but i always have to explain it in workshops to our costumers that there is to do this if they want to store the CC Files to the projects and they don't understand why there is no standart setting...
