UI - iLogic Configuration
Took me a while to find this "hidden" iLogic configuration.
To make some sense, I think this tool should be at the ilogic tab.
4 Comments
swalton
Or in the application options window.
A-M-Z
And/Or in the project file !
It wasn't the case in earlier versions, but at least since 2022 those  iLogic settings are exported with the application options when you save them.
jtylerbc
I would be okay with either of these suggestions (iLogic ribbon panel or Application Options).
However, on the default ribbon, this is the only item in a dropdown - on a panel that already has an open space for another icon.  This button immediately becomes easier to find if they just stop hiding it in the first place, even without any further changes to the ribbon or panel that it shows up on.
k.hendrickx
agreed it's not the most logical placement.
@jtylerbc : right click the button and choose "move to main panel" 😉
