Tube&Pipe 105: “Edit Connection needs an Apply Button”
Edit fitting connection needs an Apply button. If I need to edit multiple connections like when moving fittings around on a skid you start the command, edit one fitting and only have OK button. Then you need to restart the command on every fitting you need changing. Apply should accept edits and allow you to choose a different fitting to edit. While I keep selecting fittings, the connection info should update. If, by mistake, I choose the wrong fitting to edit then all I should do is click on the correct one and the edit info window to update and allow me to continue.
@dan_szymanski
