When adding bends manually the radius should point to “B” parameter by default rather than a static value. This will help when changing bend radius parameter will update all design. I am forced to edit all radius dimension and type “B” making a manual link to the parameter value. Even if I manually enter “B” in the bend operation, only the first radius gets B value while the others are referenced the first radius parameter. This creates route violations when changing size.
@dan_szymanski
