Tube&Pipe 074: “TP Rotating Fittings”
On consecutively inserted fittings while rotating a fitting the ones that follow should only rotate IF the connection is of type flanged where the bolt holes need to match. On connections like welded, clamped, joined, etc. the fittings that follow should not rotate. However as mentioned we need to be able to select multiple fittings and choose edit orientation. If it’s too difficult to implement then only rotate the ones with similar connection orientation (vector direction). Or at least prompt us if we want the connected fittings to be rotated as well.
@dan_szymanski
