This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Tube&Pipe 070: “TP Move/Restructure Browser Fittings”
Give us the option to move/restructure fittings in the browser. The results are random and you need to drag other parts around your fitting to restructure the browser pane. Adding them to a custom folder is arbitrary as well; it seems that the group you try to move can be moved only if the first fitting in the selection is movable. ?!?.
@dan_szymanski
6 Comments
jorgen
Hi, this has been an issue for about a decade now I think, and I know it has been submitted as an idea earlier but then archived.
Could we try to gather some more support this time please ? Really annoying thing...
Enable content center parts to be demoted.
Tags (2)
jingyi.liu
Hi Jorgen
The issue you described is a Tube&Pipe specific problem, I have to say it's as designed. Please refer to below idea submitted by Salariu, it's almost the same.
https://forums.autodesk.com/t5/inventor-ideas/tube-amp-pipe-070-tp-move-restructure-browser-fittings...
jorgen
Hi, I am not using Tube&Pipe, but I am using fittings found in Content Center.
jingyi.liu
Got it, if you're not using T&P, then you can use the workaround, after placing the first fitting placed from Content Center, then Copy & Paste, you will notice the difference of their icons in browser, standard part vs. Tees.
jtylerbc
In addition to @jingyi.liu's suggestion:
Even though you aren't using T&P, it is still the cause of your problem.  If you never use T&P, then you can disable the T&P add-in and remove the need for the extra step he described.  If you sometimes use it and sometimes don't, then you can use the workaround he described.
Note that disabling the add-in prevents this problem on parts placed from then on - it won't fix ones that were already placed before disabling the add-in.
jorgen
Hi, I disabled the T&P add-in and I think that actually solved the problem when placing new CC parts.
Many thanks!
Jørgen
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
