This is more of a 3D Sketch problem but it needs fixing. On 2D sketch you can right click a line towards the end and choose Delete Coincident Constraint to release it. I would like to have the same option in 3D sketch so I can disconnect a pipe segment and connect it somewhere else. Manually removing constraints is not always working. See point 24 “Constraints are not always visible for nodes”.
We need a “Delete Coincident Constraint” when right clicking route segment just like we have on 2D sketches when you right click a line. I want to be able to disconnect segments on the fly without trying to find nodes, using show constraints, hover over the node until constraint signs show up then selecting it then pressing delete. This should especially work when route has violations like minimum length segment or invalid angles so we can fix the route faster by disconnecting offending segments or inserting new ones
@dan_szymanski
![TP064.gif TP064.gif](https://forums.autodesk.com/t5/image/serverpage/image-id/372251i9973BD3F1FCDAF9A/image-size/large?v=v2&px=999)
