Tube&Pipe 052: “Route construction line visibility”
Route construction lines should be visible inside the route sketch only. As soon as you exit the route they should be off.
@dan_szymanski
2 Comments
Ruffy85
its better to get a T&P Option where you can set your default settings. Sometimes if will drop some fittings on your route, you have to be outside the route, but have to see the route as well to drop the fittings on it.
Andrew2803
And also the Included geometry should persist their invisibility, once they have been turned off.
Now they get visible upon editing, or making visible the route again and again.
