When placing fittings you get a rotation dialog but no “edit connection” or “change size” dialog. While in rotation mode an edit connection / change size should be available in the right click menu. You now need to start each command separately; you finish placing, select fitting, edit connection, select the fitting, change size, select fitting again, and so on in way too many steps. When you finish the Edit Connection /Change Size it should revert back to rotation mode dialog. I place similar fittings from adjacent runs because it’s easy but most of the time they are of different size and they need a different connecting dimension.
@dan_szymanski
![TP005.gif TP005.gif](https://forums.autodesk.com/t5/image/serverpage/image-id/372167i486E8587D3A18668/image-size/large?v=v2&px=999)
