I would like the ability to create a pattern based on a triangle or possible even a tool capable of basing a pattern on different polygons.
The image below is an example. It was created, by drawings an array of points for 1 segment of the hexagon and then using a circular pattern to add the other segments. A few of the holes do not quite fit in with the pattern so were addem manually.
The thing is it takes quite a bit of time to setup and create what is essentially a triangular or hexagonal array. Surly we can have a tool to create patterns like this? I have seen other software packages create these kind of patterns in seconds, while in Inventor I have to take the time to draw it out.
