Tracing adaptive references
Inventor seems to lack the posibility to trace references internally in parts and between parts, a posibility that would increase the effectivity and usability of skeleton modelling and adaptivity substantially.
For adaptivity there are several levels of tracing that could improve the functionality.Some parts and assemblies are created adative initially, then the adaptivity is turned off. Those components will adapt if the adaptivity was turn on again on a later stage, but how can they be found?  Maybe such components should have their own icon in the browser tree - making them easier to find?
When the adaptivity is active, it should be possible to trace the referenced parts. This could be a right-click option, or it could be available information in the document settings along with the 'adaptively used in assembly' check box.
Also the adaptive references in sketches should be possible to identify down to the parent of the projected geometry; surface, edge or sketchelement. This could also be a right-click option or hover-over-tip.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
