Toggle hole depth to point
Sometimes you would like to measure the hole depth from the top to the point (so to make sure you have enough material left). Within the hole dialoge it's only possible to select the start of the bore cone:
31 Comments
phillip3
It would be nice to be able to give the depth of a hole to the tip rather than the parallel hole section.
In real life the depth of drilling is measured from the tip of the drill bit not the parallel section.
Tags (1)
MarcoMoura9852
I've also had the same request in the past, because I'm aware this would save alot of time, and human mistakes, for the designers and for the CNC prorgraming technicians.
Made this post in the past, only suggestion from autodesk was to post it in the ideas. If it had many likes, they would look at it and work on it.
https://forums.autodesk.com/t5/inventor-forum/hole-depth-considering-drill-tip/td-p/9815869
Not sure if this is already undergoing.
Maybe your post can reinforce the need for improvement...
Good luck
Yijiang.Cai
Status changed to: Accepted
Many thanks for posting the idea to us, and tracked as [INVGEN-68018] for investigation.
kimK7B54
This request has been in for 20 years, lets cross our fingers Autodesk follows thru with the "Accepted" tag and implements this.
miechh
Has this already been implemented in Inventor 2024? Just curious.
dan_szymanski
Hello @miechh,
This capability is not available in Inventor Professional 2024. If you are not already a member of our internal feedback community, I might suggest you join via this link and check in a bit later to see what we are working on.
mluterman
@dan_szymanski  ...if that's the case, then why is it listed as "Accepted" by Yijiang.Cai above, in [INVGEN-68018]. To me, that sounds like it's getting implemented.
dan_szymanski
Hello @mluterman,
I cannot publicly share or commit to any planned functionality. What I can do is ask for our community partners to join our internal feedback community to see for yourself what we are working on. There is a good chance you might see conversations or previews regarding ideas marked as "Accepted" or "Future Consideration".
Frederick_Law
So designer need to specify drill, size, drill tip angle and drill tip shape in the drawing so machinist can use correct drill for the correct drill depth.
Also the machine shop will have every drill sharpen correctly to spec.
And every drill will be QC to keep them in spec.
I'll love to see that in ISO manual.
dan_szymanski
Hello @Frederick_Law & all,
Some possible solutions for this idea are currently under discussion on the NDA based Inventor Feedback/Beta forums. If you would like to contribute to the discussion, please apply for access using this link: https://Autode.sk/InventorBeta
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2025. Please review the Inventor 2025 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
