TOGGLE BUTTON FOR LINE WEIGHT ON / OFF IN RIBBON
My original post about this is HERE.
What I would like to see is an easy way to turn line weights on / off without having to click your way through the applications menu.
I am quite often having to turn them on and off and having to go thru half a dozen mouse clicks to do it is an annoyance.
Ideally I would like to see a radio button or something you can click once in the ribbon to achieve this, I would put it in the annotate tab, Format with edit layers.
2 Comments
sgwilliams
I would love to see this as an option. For the main reason is that when I'm doing the actual design work I turn off the line weights. When I need to publish a drawing or get a screen shot for whatever reason I need the line weights on so that the lines can be seen. This would be simple for Autodesk to do. They already have a check box form control in the "Application Options > Drawing" tab this works. As a part time software developer, I know that it would be simple to create this option with very little effort.
dan_szymanski
Idea added to backlog for future consideration [36849]. Thanks!
See also, related forum discussion
