Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Thread - External thread in Welded assembly
I would like to have thread feature in the assembly environment.
Dan
117 Comments
Is there any idea on when this feature will be added?
It's much appreciated...
@dan_szymanski Hey Dan, how's it going on this? 2018 hopefully?
gusi_cl
Should be easy to improve this feature...and it receive a lot of kudos!!
Please add as soon as possible, maybe in 2017 R2!!!
How many votes does it take to have that option available for the next Inventor release?
Does any other 3D modeling software on the market have that option available? Ive been asked to propose advanced 3D modeling software to tackle the everyday design tasks in our company and one of those tasks are external threads on weldment assemblies.
The industries we supply are Offshore and Subsea, slightly weak now but still demanding.
I am open to clarify over e-mail about where this method of machining is inevitable in our field of competence if Autodesk is interested to explore outside the box of fixed ideas how production should take place.
Lauri,
You asked: "How many votes does it take to have that option available for the next Inventor release?"
My sarcastic response would be: "the same as the number of licks it takes to get to the center of a Tootsie Roll Pop" (I think I just dated myself with that reference).
If you're shopping for mid grade/mid level CAD packages such as Inventor, Solidworks, SolidEdge, etc. I can honestly say you'll be far better with Inventor, at least over those other two I mentioned. I've dealt with them all. SolidEdge is a close second to Inventor. Avoid, and I can't stress this enough, avoid Solidworks. It's a pain in the butt to deal with, especially from a CAD Admin standpoint...unless you enjoy installing and rolling out service packs every 45 days. Plus, unless SW has reconfigured their program, you're risking issues if you build to the 3rd or higher decimal place.
Let me explain - This goes back to their 2009 release. I had both, Inventor and SW in house and was directed to decide one or the other as we didn't need both. Hired a 3rd party shop to compare both as we used them on a daily basis. One of the main things we did was import neutral files from our suppliers. So 10 random files were selected and imported into both SW and Inventor. We typically held our parts to 3 or 4 place decimals. This "test" showed that 10 out of 10 neutral files imported into Inventor were accurate to the 9th decimal. On the other hand we found that 6 out of 10 files imported into SW were off randomly as of the 3rd decimal. For us, that's a 60% failure rate. We ran the test twice more with different files each time and the same deal. SW was promptly pulled out. When I contacted SW about this issue, their reply was basically "yeah, we know. But most of our clients don't create parts that accurate". I kid you not, that was their reply. I was floored and vowed to never do business with them again.
My advice to you,
1. don't fall for the hype and claims. If you listen to SW people they'll claim the program will butter your toast in the morning if you want it to.
2. Download the 30 day trials and compare them to the way YOU will be using them on a daily basis. Keep in mind, you only have 30 days to learn the software, no where near long enough to learn the more advanced features.
3. Request a demo - they'll all offer a canned demo but as you'll find, only Adesk or one of their resellers (I suggest Imaginit) will offer to do a demo on the fly with your parts and processes. SW demo jocks will most likely demand your files up to 3 weeks in advance, they create a canned demo and they will refuse to go off script. Don't fall for the fancy pics and videos, they are heavily doctored. In my experience, only Adesk and their resellers are they only ones that'll go off script and demo on the fly and admit if their software can't do something. The other guys will insist their software can do EVERYTHING and then once you buy it they'll claim "Oh, yeah...that's coming in a future release".
4. Consider the fact that you are here on this board posting this question/comment - As typical of Adesk, these discussion/help groups and all service packs, etc. are open and free to the public. With SW, you MUST be a current paying subscriber to post anything on their official boards or to get any service packs/updates.
5. simply just do your research and come to the conclusion that works best for you. Inventor has always been the better choice for me over the years. Does it have its problems? Sure, they all do. Find me a program this complicated that doesn't. At least Adesk actually listens and allows their users to have input, even if it doesn't always work out the way we'd like.
ca-d.one
Id would be very gentle to place threads not just in ips`s.
Could you also add this function in the assembly Environment (i just mean external threads).Smiley Indifferent
Internel threads are no Problem.
+dirk+
Curtis_W
ulasdeniz
It would be very nice and useful. thanks.
See the forum
https://forums.autodesk.com/t5/inventor-ideas/thread-external-thread-in-welded-assembly/idi-p/368483...
What is the status on this item. It's something we stumble over almost every week.
We make special cylinders and they need external threads on the rod, but after welding.
(Note: back in 2004, Pro-Engineer had this function already.... )
Tags (5)
P-D91
Any operation which involves removing material should be available in assemblies.
dan_szymanski
@Anonymous  The parent/master idea you referenced above is set as "Accepted", which means it is on our road map for future consideration.  If you’re not already a member of the Inventor Feedback/beta program then click this link to apply – http://bit.ly/InventorBeta”.  You can gain insight into every project the Inventor team is working on for upcoming updates and releases.  Thanks!
P-D91
While you're on the subject of external threads.
How about adding an option to display the core diameter of the thread, on a 3D part.
Follow the below link and open the attachment.
https://forums.autodesk.com/t5/inventor-ideas/display-the-core-diameter-of-an-external-thread/idi-p/...
dan_butler_komatsu
I agree with you, this is definitely functionality we need in Inventor, very applicable in the real world. Years ago, we had Pro-Engineer. They did not have the ability to add fillets on the assembly level at the time. We tried to convince them that we needed to add fillets during machining processes. We never did get that tool from them, ended up going to Inventor as a company. I don't know if they have that ability now or not. Now we need Autodesk to give a listening ear and get this feature into Inventor, I hope they will get this done, it is a real need.
Dan Butler
Senior Designer
120 Liberty Street
Franklin PA 16323
United States
Office: +1 814 432 1221
[cid:[email protected]]
This electronic mail transmission contains information from Joy Global Inc. which is confidential, and is intended only for the use of the proper Addressee. If you are not the intended recipient, please notify us immediately at the return address on this transmission, and delete this message and any attachments from your system. Unauthorized use, copying, disclosing, distributing, or taking any action in reliance on the contents of this transmission is strictly prohibited and may be unlawful. Privacy-JGI
External thread machining on weldments/assemblies is a core competency of manufacturing. When will this feature be developed?  This topic seems to have some history of being disregarded.
scottmoyse
This came up during all 5 cities we did tech events in New Zealand this week.
gusi_cl
I hope that after 200 kudos and 2 year developers introduce this feature. We need it!!
dhaval3112
External thread must be there in assembly level. We can not make derive part for each assembly bcoz derive part can't get i properties & bill of material of assembly. Thanks
dan_butler_komatsu
External threads in Welded Assemblies has been approved by the Autodesk Inventor people. It is in process of being developed into the software. It takes time to develop and work it out. Also, they are doing much to implement many other ideas that users have suggested. It is on its way.
BCrosby
Original post - 2012
Reviewed and accepted - 2013
Gathering support - 2014-15
It's good to know Autodesk is working on this but 5+ years...
RichM1
Only 4 years 11 months and 10 days.
Is there a time frame for implementation?
If they would stop changing all the things that work well and concentrated more on adding missing features we might get it faster.
