Normally "Skip migrated" is marked when you migrate files. When the task starts, it will open every single file in Inventor to see if it is migrated. Then it is skipped. It could save MUCH time if this first initial check was done with Apprentice Server.
Specially if a task has crashed and must run again. Then it can take hours to pick up where it left because it opens every single file again.
