STRESS ANALYSIS - FEATURE EXCLUSION ERROR - Accept Button
Please add "Accept" button instead of just "Cancel".
I don't care if there are (other) sketch errors...I can deal with those later if even necessary for what I'm trying to accomplish.
I've actually noticed this missing Accept button for a couple different errors (I think another area was trying to add/edit a Joint but since there were existing conflicting errors, it only had Cancel...just let me hit Accept and leave it 'orphaned'/unresolved, and I will fix it later)!
The following errors were encountered while attempting to exclude this feature(s):
Suppress Feature: problems encountered while executing this command.
Warning occurred during update
Relationship was placed with respect to sketch geometry that needs investigation.
1 Comment
drawings
I complained about the lack of being able to accept joint errors before and it has been fixed. If you had more than one joint with an error it was impossible to fix either without suppressing the rest.
I just posted another idea about constraint errors keeping features from being excluded in simulations even though simulations do not use the constraints.
We need the flexibility to ignore an error for the time being if it does not cause the current commands function to be impossible..
