Splice joint in a Cable
There are times when using a cable harness that a wire needs to go to multiple positions in one connector. Unable to use the splice function with a cable harness. In real life we would create a 2-1, 3-1 or even 4-1 wire splice joint. Upgrade the Cable & Harness functionality to allow this.
Also update the wire table to actually use Excel and not a comma delaminated table. Currently unable to import the wire table into the nailboard drawing. The work around I have found is to open the table externally in Excel after creating it. Then save as a excel workbook. Then I can bring the table into the nailboard drawing.
The Cable & harness environment is in dire need of general system update and functionality upgrades.
