Hi
A feature to save a lot of clicks in the daily work would be to implement the possibility to add customized shortcuts.
When adding a component to an assembly, or opening a component, Inventor remembers the folder location from the last opened or added component, which is good. The problem is when you are looking for files, spread out in a big folder hierarchy.
My idea is to implement a function to add customized shortcuts in the open/place component dialog boxes.
In the 2017 version there is something similar to what I'm after at "My Home" Shortcuts that you could use for open files. But normally you don't want to go via the "My Home" window just to open a file. It should be accessed via the open icon you always have in the top left corner. And it would be even more useful in the Place Component dialog box.
I hope more people see the benefits here!
