Specific sketch reference
This is more of an improvement of an existing feature. When you get the error message: "Sketch#: Could not build this Sketch", the message does not tell you where the sketch is located and there is no way to navigate to the sketch from the dialogue window. This is a problem if your assembly contains 1000+ parts or drawing consists of multiple sheets.
This error message can typically appear when trying to copy and paste a drawing sheet, and it will then block the operation. Then if the message says "Sketch2: Could not build this Sketch" it can be anyone of the 200 instances of "Sketch2" I have in my parts or drawing views. It can be very tedious and time consuming to locate that sketch. Especially since it is not necessarily have an explanation mark on it in the drawing tree.
The idea is for the warning to be more specific on which part or drawing view this sketch is located, or a right click option for navigating to it directly.
