I propose that trimming geometry in a sketch preserves the behavior of the parent geometry. Looking at the picture below, if you trim the 2 edges of the 1 inch circle, the dimension is deleted and the 2 arcs are now unrelated. Sometimes this is exactly what you want. Therefore a new trim command should be added or you have a checkbox that says “Preserve sketch constraints and dimensions” or something similar to that. This trim command makes the new geometry behave like the old geometry while also keeping the dimensions. This saves time and makes the operator more efficient by not having to apply the constraints again.
Note that an equals constraint was added to the 2 arcs to maintain their behavior.
