Slotted hole feature
I think it would be nice to have a slot feature in the hole/thread command for modeling. What that would look like; You select where you would want the center points for the radius, and you could pick within the menu, the distance (center to center, which could already be covered by the pre dimensioned points), radius of arc, and depth of slot. It would streamline drawings also as clicking the hole/thread dim could pull up its needed radius, depth, and center to center length, which would combine 3 different processes into one. To expand upon the drawing part, if you already have an ordinate set created with dims along the same axis as the slot being created, you could click an option to have the center-to-center dims to be incorporated into said ordinate set. Thank you!
3 Comments
At this moment you can use iFeature.
colby_messenger
thank you
jelle_nobus
I also think it's somewhat strange a slotted hole feature is not present, or at least build into the existing hole feature.
