slot joint constraint
when applying a joint constrain on a bolt going into the center of a slot, it would be helpful if the very center of the slot would highlight as an option. today it only picks up the center points and midpoint of the walls
43 Comments
I've been using inventor for about 9 years on and off and I've always wished there was a better slot command. in my line of work i do a lot of slots not limited to just through slots but including counter-bored slots, counter-sunk slots, and sometimes needing to determine the size of clearance for a bolt to put in a slot. I wish there was a feature in the hole command that allowed for this to be done in one feature by either a set of points or just a single point and distance/direction. and adding this feature to the hole note in the drawing environment
I've also used other products besides Autodesk and one feature i have found very useful in other products is a mid-plane constraint; where you select the two faces of one part and two faces of another and it centers it without the need of adding a bunch of planes... also back to the slot features i wish there was an easier way to constrain a bolt into the center of a slot without the creation of a bunch of planes or axis'
Andrew2803
The Insert Constraint could be pimped up in further by giving an edge-aligning option.
This would be able to sort out for many of us the pain of missing Slot Constraint.
There is still a question though how this idea could be applied on a curved face... See pics below:
Andrew2803
hi @Anonymous:
Have a look at my idea to the part of your problem:
https://forums.autodesk.com/t5/inventor-ideas/edge-aligned-insert-constraint-for-slots/idi-p/7258364
jbwaiteG7526
The slot creation feature in sketch mode has the option for a Center Point slot where you select the center point for the slot, then the offset from the center ( essentially slot length ) and then lastly the slot diameter.  The center point can be used to dimension where the slot is positioned. Would it not be easy to maintain the center point selected as an axis that can be used in an insert constraint.  Even if you have to use two constraints ( mate axis, mate face ) all features are available and it can be done in just a few clicks.
Yes we can make a hole just slightly larger than the slot by a few thousandths and use IT to constrain to another part but it is not a "best practice" method because the difference is actually "seen" by CAD driven machinery be it laser cutting or machining.  It would seem so easy for Inventor to simply carry forward that center point selection.
dg2405
I've created some code to place parts on slots, it works with every slot also with slots from imported models. Here you see:
https://youtu.be/JvKnPWatsDs
dg2405
PaulMunford
Hi All,
I created a Screencast showing Joints and Slots in Inventor 2018 in reply to this thread:
https://forums.autodesk.com/t5/inventor-ideas/i-want-a-slot-hole-command/idi-p/7453937
You can watch the Screencast here:
https://knowledge.autodesk.com/community/screencast/a9a7eeab-d53a-47a7-a522-a315b15f5d4e
Does this help with the problem?
Paul
PaulMunford,
Thanks for the video. It's somewhat encouraging to see this added functionality, but unfortunately this only works for slots that have been drawn in Inventor 2018. This won't work on any parts created in older versions, so for companies like mine that constantly assemble components drawn in various versions of Inventor, trying to guess which part was drawn in 2018 and which was drawn in previous versions is unrealistic. Because of this inconsistency, I don't see us using this functionality unless we are using all new parts. Rather than changing the slots, Autodesk should add the functionality of selecting the center of the slot, to the Joint and the Constraint features. This would help companies with large databases of parts drawn in various versions of Inventor.
Denis.
dg2405
Hey Denis,
try this vba-code, it saves us a lot of time!
Dim oAllOccsCollection As ObjectCollection
Dim oHelpOcc As ComponentOccurrence
Dim oAllCOnstraintsCollection As ObjectCollection
Sub Scheibe_auf_Langloch()
On Error GoTo Ende
'Auf Bg zugreifen
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = oApp.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = oAsmDoc.ComponentDefinition
'Scheibe greifen
Dim oScheibenKreis As EdgeProxy
Set oScheibenKreis = oApp.CommandManager.Pick(kPartEdgeCircularFilter, "Select circle from placing part")
'LanglochArc greifen
Dim oLanglochArc As EdgeProxy
Set oLanglochArc = oApp.CommandManager.Pick(kPartEdgeCircularFilter, "Select arc from slot")
'Occurrence von Scheibe ermitteln
Dim oScheibeOcc As Inventor.ComponentOccurrence
Set oScheibeOcc = oScheibenKreis.Parent.Parent
'Fläche von Occurrence ermitteln
Dim oNormteilFaceProxy As FaceProxy
For Each oNormteilFaceProxy In oScheibenKreis.Faces
    If oNormteilFaceProxy.SurfaceType = kPlaneSurface Then Exit For
Next
'Rechtwinklige Ursprungsebenen ermitteln
Dim oPerpendWorkPlaneProxy1 As WorkPlaneProxy
Dim oPerpendWorkPlaneProxy2 As WorkPlaneProxy
Dim oPlane1 As WorkPlane
Dim oWorkPlaneProxy1 As WorkPlaneProxy
Set oPlane1 = oScheibeOcc.Definition.WorkPlanes.Item(1)
Call oScheibeOcc.CreateGeometryProxy(oPlane1, oWorkPlaneProxy1)
Dim oPlane2 As WorkPlane
Dim oWorkPlaneProxy2 As WorkPlaneProxy
Set oPlane2 = oScheibeOcc.Definition.WorkPlanes.Item(2)
Call oScheibeOcc.CreateGeometryProxy(oPlane2, oWorkPlaneProxy2)
Dim oPlane3 As WorkPlane
Dim oWorkPlaneProxy3 As WorkPlaneProxy
Set oPlane3 = oScheibeOcc.Definition.WorkPlanes.Item(3)
Call oScheibeOcc.CreateGeometryProxy(oPlane3, oWorkPlaneProxy3)
If oApp.MeasureTools.GetAngle(oWorkPlaneProxy1, oNormteilFaceProxy) = 0 Then
    Set oPerpendWorkPlaneProxy1 = oWorkPlaneProxy2
    Set oPerpendWorkPlaneProxy2 = oWorkPlaneProxy3
End If
If oApp.MeasureTools.GetAngle(oWorkPlaneProxy2, oNormteilFaceProxy) = 0 Then
    Set oPerpendWorkPlaneProxy1 = oWorkPlaneProxy1
End If
If oApp.MeasureTools.GetAngle(oWorkPlaneProxy3, oNormteilFaceProxy) = 0 Then
    Set oPerpendWorkPlaneProxy2 = oWorkPlaneProxy2
End If
'Maximale Kreisfläche ermitteln
Dim oMaxCircFace As Face
Dim myList As Object
Set myList = CreateObject("System.Collections.ArrayList")
For Each oMaxCircFace In oScheibeOcc.SurfaceBodies.Item(1).Faces
    If oMaxCircFace.SurfaceType = kCylinderSurface Then
        myList.Add (oMaxCircFace.Geometry.Radius)
    End If
Next
myList.Sort
        If oMaxCircFace.Geometry.Radius = myList.Item(myList.Count - 1) Then
            Exit For
        End If
    End If
Next
Dim Durchmesser As Double
Durchmesser = Round(oMaxCircFace.Geometry.Radius * 20, 3)
'Langloch
'Langlochradius
Dim Langlochradius As Double
Langlochradius = Round(oLanglochArc.NativeObject.Geometry.Radius, 3)
'Fläche von Langloch ermitteln
Dim oLanglochFaceProxy As FaceProxy
For Each oLanglochFaceProxy In oLanglochArc.Faces
    If oLanglochFaceProxy.SurfaceType = kPlaneSurface Then Exit For
Next
'Occurrence ermitteln
Dim oLanglochOcc As Inventor.ComponentOccurrence
Set oLanglochOcc = oLanglochArc.Parent.Parent
'Prüfen ob oLanglochOcc eine Occ der Bg ist
Dim oParentOcc As ComponentOccurrence
Dim IstBgOcc As Boolean
IstBgOcc = False
For Each oParentOcc In oAsmCompDef.Occurrences
    If oParentOcc Is oLanglochOcc Then IstBgOcc = True
Next
If IstBgOcc = False Then
        If oParentOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call SearchAllOccs(oParentOcc, oLanglochOcc, 1)
            If Not oHelpOcc Is Nothing Then Exit For
        End If
    Next
End If
'Alle Zusammenhängenden Occs in Collection
Set oAllCOnstraintsCollection = ThisApplication.TransientObjects.CreateObjectCollection
Set oAllOccsCollection = ThisApplication.TransientObjects.CreateObjectCollection
Call oAllOccsCollection.Add(oScheibeOcc)
Call SearchAllOccsInOcc(oScheibeOcc, 1)
'Alle gleichen Flächen in Collection
Dim oBodyFaceCol As FaceCollection
Set oBodyFaceCol = ThisApplication.TransientObjects.CreateFaceCollection
Dim oBodyFace As Face
For Each oBodyFace In oLanglochFaceProxy.NativeObject.Parent.Faces
    On Error Resume Next
    If oBodyFace.SurfaceType = kPlaneSurface Then
        If oApp.MeasureTools.GetAngle(oLanglochFaceProxy.NativeObject, oBodyFace) = 0 Then
            If oApp.MeasureTools.GetMinimumDistance(oLanglochFaceProxy.NativeObject, oBodyFace) = 0 Then
                Call oBodyFaceCol.Add(oBodyFace)
            End If
        End If
    End If
    On Error GoTo 0
Next
On Error GoTo Ende
'Check for same Arcs
Dim oCircleProxy As EdgeProxy
Dim oCircleCollection As ObjectCollection
Set oCircleCollection = ThisApplication.TransientObjects.CreateObjectCollection
Call oCircleCollection.Add(oLanglochArc)
Dim IsConvexArc As Boolean
Dim oBodyProxy As SurfaceBodyProxy
For Each oBodyProxy In oLanglochOcc.SurfaceBodies
    For Each oCircleProxy In oBodyProxy.ConvexEdges
        If oCircleProxy.GeometryType = kCircularArcCurve Then
            If Round(oCircleProxy.Geometry.Radius, 3) = Langlochradius _
                And Round(oApp.MeasureTools.GetMinimumDistance(oCircleProxy.Geometry.Center, oLanglochFaceProxy), 5) = 0 _
                And Round(oApp.MeasureTools.GetMinimumDistance(oCircleProxy.PointOnEdge, oLanglochFaceProxy), 5) = 0 _
                And Round(oCircleProxy.Geometry.SweepAngle, 5) = Round(4 * Atn(1), 5) Then
                    Call oCircleCollection.Add(oCircleProxy)
                    IsConvexArc = True
            End If
        End If
    Next
    For Each oCircleProxy In oBodyProxy.ConcaveEdges
                    IsConvexArc = False
            End If
        End If
    Next
Next
'Wenn Concave und Convex keine Länglöcher enthält, dann muss über die Flächen gegangen werden bei "Check for same Arcs"
If oCircleCollection.Count = 1 Then
     Call Scheibe_auf_Langloch_alte_Version
     GoTo Ende
End If
Dim oEdgeLineProxy As EdgeProxy
Dim oCircleProxy2 As EdgeProxy
Dim oCircleProxy3 As EdgeProxy
Dim oLanglochCollection As ObjectCollection
Set oLanglochCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oCircleProxy In oCircleCollection
    For Each oCircleProxy3 In oLanglochCollection
        If oCircleProxy Is oCircleProxy3 Then
            GoTo NextFor
        End If
    Next
    For Each oEdgeLineProxy In oCircleProxy.TangentiallyConnectedEdges
        If oEdgeLineProxy.CurveType = kLineCurve Then
            If Round(oApp.MeasureTools.GetMinimumDistance(oEdgeLineProxy.StartVertex.Point, oLanglochFaceProxy), 3) = 0 _
            And Round(oApp.MeasureTools.GetMinimumDistance(oEdgeLineProxy.StopVertex.Point, oLanglochFaceProxy), 3) = 0 Then
                For Each oCircleProxy2 In oEdgeLineProxy.TangentiallyConnectedEdges
                    If Not oCircleProxy2 Is oCircleProxy Then
                        Call oLanglochCollection.Add(oCircleProxy)
                        Call oLanglochCollection.Add(oEdgeLineProxy)
                        Call oLanglochCollection.Add(oCircleProxy2)
                        GoTo NextFor:
                    End If
                Next
            End If
        End If
    Next
NextFor:
Next
'SelectSet leeren
Call oAsmDoc.SelectSet.Clear
'Durchschleifen
For i = 1 To oLanglochCollection.Count Step 3
    'Prüfen ob Constraint vorhanden
    Dim oConstraint As AssemblyConstraint
    If IstBgOcc = True Then
        For Each oConstraint In oLanglochOcc.Constraints
            If oConstraint.Suppressed = False _
            And oConstraint.HealthStatus = kUpToDateHealth Then
                If TypeOf oConstraint.EntityOne Is EdgeProxy Then
                    If oConstraint.EntityOne.GeometryType = kCircularArcCurve Then
                        If Round(oApp.MeasureTools.GetMinimumDistance(oConstraint.EntityOne.Geometry.Center, oLanglochCollection(i).Geometry.Center), 3) = 0 Then GoTo EndEdgeLoop
                    End If
                End If
                If TypeOf oConstraint.EntityTwo Is EdgeProxy Then
                    If oConstraint.EntityTwo.GeometryType = kCircularArcCurve Then
                        If Round(oApp.MeasureTools.GetMinimumDistance(oConstraint.EntityTwo.Geometry.Center, oLanglochCollection(i).Geometry.Center), 3) = 0 Then GoTo EndEdgeLoop
                    End If
                End If
            End If
        Next
    Else
        For Each oConstraint In oParentOcc.Constraints
                    End If
                End If
                    End If
                End If
            End If
        Next
    End If
    'Ursprüngliche Teileanzahl festhalten
    Dim occCount As Integer
    occCount = oAsmCompDef.Occurrences.Count
    Dim oNewScheibeOcc As ComponentOccurrence
    If i <> 1 Then
        'Teile einfügen
        Call oAsmDoc.SelectSet.SelectMultiple(oAllOccsCollection)
        ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd").Execute
        ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd").Execute
        'New originOcc ermitteln
        For Z = occCount + 1 To oAsmCompDef.Occurrences.Count
            If oAsmCompDef.Occurrences(Z).Definition.Document.PropertySets("Design Tracking Properties").Item("Part Number").value _
            = oScheibeOcc.Definition.Document.PropertySets("Design Tracking Properties").Item("Part Number").value Then
                Set oNewScheibeOcc = oAsmCompDef.Occurrences(Z)
                Exit For
            End If
        Next
    Else
        Set oNewScheibeOcc = oScheibeOcc
    End If
    'Fläche von Normteil ermitteln
    Dim oNativeNormteilFace As Face
    Set oNativeNormteilFace = oNormteilFaceProxy.NativeObject
    Dim oFace As Face
    For Each oFace In oNewScheibeOcc.Definition.SurfaceBodies.Item(1).Faces
        If oFace Is oNativeNormteilFace Then
             Exit For
        End If
    Next
    'ProxyFläche von Normteil ermitteln
    Dim oNewNormteilFaceProxy As FaceProxy
    Call oNewScheibeOcc.CreateGeometryProxy(oFace, oNewNormteilFaceProxy)
    'Rechtwinklige Normteilebenen ermitteln
    Dim oNativePerpendWorkPlaneProxy1 As WorkPlane
    Set oNativePerpendWorkPlaneProxy1 = oPerpendWorkPlaneProxy1.NativeObject
    Dim oWorkplane1 As WorkPlane
    For Each oWorkplane1 In oNewScheibeOcc.Definition.WorkPlanes
        If oWorkplane1 Is oNativePerpendWorkPlaneProxy1 Then
             Exit For
        End If
    Next
    Dim oNewPerpendWorkPlaneProxy1 As WorkPlaneProxy
    Call oNewScheibeOcc.CreateGeometryProxy(oWorkplane1, oNewPerpendWorkPlaneProxy1)
    Dim oNativePerpendWorkPlaneProxy2 As WorkPlane
    Set oNativePerpendWorkPlaneProxy2 = oPerpendWorkPlaneProxy2.NativeObject
    Dim oWorkplane2 As WorkPlane
    For Each oWorkplane2 In oNewScheibeOcc.Definition.WorkPlanes
        If oWorkplane2 Is oNativePerpendWorkPlaneProxy2 Then
             Exit For
        End If
    Next
    Dim oNewPerpendWorkPlaneProxy2 As WorkPlaneProxy
    Call oNewScheibeOcc.CreateGeometryProxy(oWorkplane2, oNewPerpendWorkPlaneProxy2)
    'Abhängigkeit vergebn
    Dim oDoc As Document
    Set oDoc = oNewScheibeOcc.Definition.Document
    If IsConvexArc = True Then
        If Durchmesser <= Round(oLanglochCollection(i).Geometry.Radius * 20, 3) Then
            Call oAsmCompDef.Constraints.AddFlushConstraint(oNewNormteilFaceProxy, oLanglochFaceProxy, 0)
        Else
            Call oAsmCompDef.Constraints.AddMateConstraint(oNewNormteilFaceProxy, oLanglochFaceProxy, 0)
        End If
    End If
    If IsConvexArc = False Then
        Call oAsmCompDef.Constraints.AddMateConstraint(oNewNormteilFaceProxy, oLanglochFaceProxy, 0.1)
    End If
    Call oAsmCompDef.Constraints.AddMateConstraint(oNewPerpendWorkPlaneProxy1, oLanglochCollection(i), 0, kNoInference, kInferredPoint)
    Call oAsmCompDef.Constraints.AddMateConstraint(oNewPerpendWorkPlaneProxy1, oLanglochCollection(i + 2), 0, kNoInference, kInferredPoint)
    Call oAsmCompDef.Constraints.AddMateConstraint(oNewPerpendWorkPlaneProxy2, oLanglochCollection(i + 1), 0, kNoInference, kInferredPoint)
EndEdgeLoop:
Next
Ende:
'Selectset zurücksetzen
'update
oAsmDoc.Update
End
End Sub
Private Function SearchAllOccsInOcc(Occurrence As ComponentOccurrence, Level As Integer)
    For Each oConstraint In Occurrence.Constraints
        Dim ConstraintVorhanden As Boolean
        ConstraintVorhanden = False
        For i = 1 To oAllCOnstraintsCollection.Count
            If oConstraint Is oAllCOnstraintsCollection(i) Then
                ConstraintVorhanden = True
                Exit For
            End If
        Next
        Call oAllCOnstraintsCollection.Add(oConstraint)
        Dim oOcc As ComponentOccurrence
        Set oOcc = oConstraint.AffectedOccurrenceOne
        Call oAllOccsCollection.Add(oConstraint.AffectedOccurrenceOne)
        If ConstraintVorhanden = False Then Call SearchAllOccsInOcc(oOcc, 1)
        Set oOcc = oConstraint.AffectedOccurrenceTwo
        Call oAllOccsCollection.Add(oConstraint.AffectedOccurrenceTwo)
    Next
End Function
Private Function SearchAllOccs(Occurrence As ComponentOccurrence, TargetOcc As ComponentOccurrence, Level As Integer)
    For Each oOcc In Occurrence.Definition.Occurrences
        If oOcc.Definition.Document.PropertySets("Design Tracking Properties").Item("Part Number").value _
        = TargetOcc.Definition.Document.PropertySets("Design Tracking Properties").Item("Part Number").value Then
            Set oHelpOcc = oOcc
            Exit Function
        Else
            If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
                Call SearchAllOccs(oOcc, TargetOcc, Level + 1)
            End If
        End If
    Next
End Function
MrSmithtastic
@dg2405 but what does your code do?
dg2405
MrSmithtastic
Nice!! Thanks for sharing!
dg2405,
Thanks for sharing that! Very nice tool.
tmuel
Please see this screen cast for further information:
https://www.screencast.com/t/yguYo5H7AG
We work with large equipment that contains many punched slots. These slots also require bolt assemblies. The holes are typically slotted to allow for manufacturing and temperature variance. It is very time consuming for our engineers to manually constrain to these slotted features. Work features must be created manually because work/surface features are not supported in the punch iFeature tool. This would be a great place to use iMates, but those are also not supported in the punch tool (but should be). The punch iFeature author tool gives us the capability to author a center point; however, this center point cannot be used for creation of constraints or joints in an assembly.
Please allow a sketch point to be a valid selection for Joints and Constraints.
Constraining to the center of a slot is clearly a common need, as indicated by these other posts:
https://forums.autodesk.com/t5/inventor-ideas/slot-joint-constraint/idi-p/5169277
https://forums.autodesk.com/t5/inventor-ideas/constraint-and-slot-features/idi-p/7258121
https://forums.autodesk.com/t5/inventor-ideas/slots-in-bolted-connection/idi-p/3777134
https://forums.autodesk.com/t5/inventor-ideas/allow-work-features-and-surfaces-in-ifeatures/idi-p/39...
Tim
Tags (4)
alexraun
inventor 接頭約束 2015 和 2017 幾何點差異問題 ,2017版後在長圓槽無法抓取幾何中心,能否回復0至2015版本
Tags (2)
jingyi.liu
Hi Alex
Sorry for that inconsistency. As you commented, Inventor 2015 supported to snap the centroid of the profile, but it may lead to unexpected result, so the behavior was changed. Below is  the request for snapping center point of Slot, please cast your vote there.
Jingyi
I often have holes lining up with slots, can you modify one or more of the constraints (mate and insert) to grab the center 'axis' of the slot.
Tags (1)
jingyi.liu
Hi
Thanks for your feedback, please cast your votes to below similar idea.
Btw, do you use Joint Command? Is it helpful if we support Joint command to select the 'center' of the slot?
Jingyi
dan_szymanski
Status changed to: Accepted
Accepted idea [16348]. Thanks!
PaulMunford
Yay!
Technology Administrators
