Sketch Insertion/ Connection points
Creating sketch symbols with insertion points and connections points in a drawing.
I would like to be able to snap the sketch points to a Border, to a Parts List or other sketches.
This does work as said. When it does not work is: If i select multiple sketched items and want to snap them to the border to make flush, this will not happen. It does not snap if I select more then one item.
Example: The Reference Doc Table below. when inserted I can snap it to the border no problem, then I put more sketch ref doc to add, they will snap to each other with the points no problem, but if I move them (select more then one) the snap does not work.
Can we get the snap option on sketch drawing connection or insertion points snap to border when more then one sketch is selected.
thank you Sergio
