Use case
We create simplified/substitute representations of assemblies that get placed into large layouts. To make deriving them easier, we first set up a design view representation without Content Center parts. In the simplified model, every hole that defines an interface or mating condition to a neighbouring component must be preserved, while holes and pockets of the same type and size elsewhere on the model should be removed.
Problem
In the Simplify property panel, Remove Features lets us set Holes, Pockets, Tunnels etc. to All or Range – but the only way to protect the interface holes is the Preserve selector, and features have to be picked one at a time. There is no multi-select, no window/box selection, and no way to select by geometric context. On models with many interface holes this becomes a long, error-prone clicking exercise. It gets worse because holes also match the Tunnel definition, so removals we did not intend have to be corrected through Preserve as well. Since Simplify in a part is a browser feature that recomputes as the geometry changes, the selection work also has to be revisited whenever the source model is edited.
Requested improvement
Make Preserve behave like other selection sets in Inventor:
- Multi-select (Ctrl/Shift), plus window and crossing-window selection
- Face-driven selection: pick a face and automatically preserve every hole, pocket or tunnel intersecting that face
- Select-similar / select-by-size, so all holes of one diameter can be preserved in one step
- Easy removal of entries from the Preserve list, and a readable list of what is currently preserved
Benefit
Far fewer clicks on large assemblies, reproducible simplified models, less rework after design changes, and a much lower risk of accidentally removing a hole that another component mates to.
