Simple Part List
Simple Part List
When I'm using the BOM on a drawing, I generally prefer to use Content Center names since they update automatically and I don't have to keep track.  However, this is something of an issue with things like bolts and washers as they tend to use the full ANSI code spec in the part number list.  This is way more information than is useful for a general fabrication drawing.  I'd like a "simple ID" check box on the BOM generation screen that lists things like "Hex Bolt 1"-6 x 5" Long" or "Steel Pipe 2" Sch80 - 21' " would be a more compact way to say the same thing.  This would be something with a check box somewhere in the options menu for the best, as it's most likely that some people would be using the full nomenclature as opposed to simplified nomenclature (I work with fabricators, simple works best with them).
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
