Show only
Search instead for
It would be be great if we could show iProperties inside the normal Inventor Open dialog box - very much like how you can show Vault properties in the Open from Vault dialog box:
Autodesk please add this to the open dialog box, i have been an ambassador for the open/projects dialog which Solidworks doesn't have. could you update design assistant at the least integrate it,
A good app on your platform is Assembly copier, add such capabilities to design assistant, the current one is appalling
