I am very interested in aviation type sheet metal features and workflows using the sheet metal environment.
Inventor's intuitiveness and feature UI is really unparalleled, and I do appreciate these.
That said, we need corner treatments to behave as specified in the interface, and some additional features added.
The initial items that come to mind are bend / corner treatments, and joggles.
Joggles allow us to lap an L-shaped rib (and other shapes) from atop a single sheet and jump above another layer of sheet metal, within a continous part.
This is physically pressed in the shop or on a manufacturing press. We need to be able to add these features. If not for an L-shape, then at least for a flat sheet. We can do it with a couple processes, but it should be added as a single, intuitive sheet metal feature; "pick base feature face -> pick feature to jog to -> DONE.
Corner treatments are the worst folks. If a proposed bend (flange, etc.) lies against an existing bend somewhere (including in an unfolded feature), Inventor ignores treatments and reverts to a tear type instance. In aviation we drill a hole at the bend treatment corner, and cut the excess material out before sanding smooth. What results is a flat pattern, containing a 90° L-shape cutout with a TANGENT corner round at the bend. We DO NOT punch into the land areas of the bent sheet metal frame members with any cutouts.
The work around is to avoid treatments in Inventor, and add corner rounds to unfolded feautres. This is an acceptable (but sucking) workaround, HOWEVER the Flat-Pattern FAILS if any corner rounds are applied to an UNFOLDED feature.
These are two examples of what we need some help with, and areas that enable other vendors keep their customers subscription in their pocket.
Community thoughts? Workarounds?
