Sheet metal drag arrows with editable values nearby for length and width on preview
Just like you can drag an extrusion in and out when you are in the tool, I'd like to see a preview and drag option on sheet metal flanges, including for the flange width instead of having to go into a separate offset tab and type in numbers for both sides. Too many steps. Adding editable numbers and drag arrows on the screen where the flange is would be so much nicer and faster.
1 Comment
MattH_Work
Fusion does this, and I believe Fusion shares the same Sheet Metal code base as Inventor, soooo, If Fusion can do it, how hard would it be for Inventor
