Sheet Metal - direct manipulation that recognizes and preserves the features
We need the ability to inside inventor use the direct editing tool to modify sheetmetal parts. At the time we need to select faces to move or manually manipulate a flange. It would be nice if we could (for example) select a single face of a flange and manipulate it. by manipulating the face the whole flange and its features should ride along with it.
Also, when mitering a contour flange end with direct edit, we need the option to always keep faces normal - it really is sheet metal, if we need anything else we should reach out to the part modification tab, by which the software should recognize that we need to modify the sheet.
