I often have issues with constraints making errors, because there is a part, there is 0.001 mm off or some equal ridiculous small offset.
I would like to be able to set inventor to always tolerate offset there are less than 0,05 mm offset. and just place the things as well as possible within that tolerance, is that possible.
like in the attached example. is the correct position for Bend_3
X: -96,873629023 mm
Y: -233,873629023 mm
from Bend_1
If X is -96,8737 mm instead, it complains.. so that is less than 0,0001 mm off.
I can understand that 0,0001 mm can be important if working with microscopic things, but I am working with welded parts and pipes, where the smalles pipes we use are Ø35 mm, so all those tiny decimals it totally unimportant for us.
I do know, that I can set min/max limits in each constraint, but I would very much prefer to be able to do it as a world setting, or maybe just as a dokument setting. but I can't find anywhere so set it.
Kind regards Morten.
