In the assembly environment will be nice to have a most used constrain set as default. I use very often the Insert constrain during assembling parts and I want to have it ready for action when the Constrain function is call. Make the setting available in the Application Options.
Another possibility could be to retain the last used constrain option to be available at the next call of the Constrain function, or set it automatically based on the most used constrain in the assembly.
With many thanks,
Lucian Crisan
