Hi All,
Since Inventor 2018 Autodesk changed the STEP document angle unit from “Degree” to “Radian” . The reason is to keep consistent across products, including Inventor, Solidworks, Creo, etc.
We work only with degrees with the angel unit. Now if I import a STEP assembly I have to set the angle unit in every part to Degrees what costs a lot of time.
When you import a STEP file in the options you can set the Length Units. The idea is to also have an option to set the Angle unit so you can choose Degrees.
Thanks for voting!
