Select pattern or folder in drawing browser
Will be very helpful if could be possible to select whole pattern or folder in browser in drawing environment. We often need to switch visibility or hidden lines of group of elements and there is necessary to select each element only.
Petr
4 Comments
In my assembly, I tend to organize parts into folders (like booth panels, grating, structural steel, etc). I have several component patterns that get automatically grouped together (like bolt patterns).
In the assembly environment, you can toggle visibility of entire folders or component patterns.
In the drawing environment, you have to expand all children and either individually toggle visibility or highlight multiple and toggle them all at once.
Is there a reason that the drawing environment won't let you toggle the entire folder or component pattern at once like the assembly environment can? It is a royal pain when you have a large component pattern to expand everything to select it all.
Tags (2)
jalexander
This was a great idea back in 2013 when Petr first posted and it still is a good idea.  When will this be implemented!?
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
