While working in the 3d modeling environment(.iam or .ipt)I would like to be able to "Right click" on a work plane feature in the browser and have an option to directly "Section Part". Default would be half section.
Currently, you must customize the marking menu to get this option, and you can only select objects from the graphical work area. This is a little messy because we don't always like to display work planes. Therefore you have turn visibility on, then turn it back off, then back on, then back off..... 🙂
To make an even further request, by default, when a face or work place is selected, the create half section view command should already be there out of the box.
