Save and use "Multi-Value" dimension sets
Be able to save "Mult-Value" dimension sets in Part files and then choose which set you want to activate when that part is placed in an assembly.
This would mean you could place normal parts with different size options like you can place iParts.
This would be much faster than creating iParts. Many times you need an instance of a part with something a slightly different size to the original and this would be great.
It would be good if we could incorporate "Suppression" of features in this some how too?
3 Comments
FProcp
The saved "Multi-Value" dimension sets could possibly be handled like "Design Views" and "Level of Details".
When creating the drawings a different "Multi-Value dimension set" could be activated. Then for example when taking a section through a cylindrical object, features that are not square to the section view (the section doesn't cut through them) could be rotated around the central axis to show up nicely in the section (show section going through them).
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
