Run iLogic Event Trigger with iPart Member
There are iLogics that, for example, create or write the display name in the Model Browser based on a schema when an event is triggered.
In particular, if the display name is supposed to include the file name (which is generated by a Vault number generator), certain properties cannot be controlled using the iPart tables.
This results in display names that no longer match the respective file.
( https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/No-iLogic-event-...
