Rugosity Symbol
Rugosity Symbol
In drawing enviroment, the symbol of surface state don't remember last value. Every new symbol inserted require redigit the value again.
Also missing the symbol summarizing the roughness design.
1 Comment
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support. This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes.
This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
Btw, please refer to below idea, which is similar to your request, you can cast your kudos to gather more support.
https://forums.autodesk.com/t5/inventor-ideas/remember-last-setting-for-surface-texture/idi-p/571796...
 - INV.IdeaReview
