Retrieve Model Annotations
Would it be possible to expand the features and possibilities of the retrieve model annotation function in a drawing.
For example:
 - When modeling a part, when you're putting in dimensions to make your sketch fully constraint, you can select or mark those dimensions with, for example an '*'.
Keeping in mind that you will be showing this dimension later in a drawing.
This way you don't have to search the useful dimensions in a bunch of dimensions stacked on each other.
- Selecting a specific part (in an assembly).
If you used a single part multiple times in 1 assembly, you just select one of these and only that selected part in the assembly gets the dimensions shown
(not all of that same part, which is redundant).
I hope this was helpful, Thanks for reading
Ian
