I really enjoy using Multi-Body Parts to create subsequent assemblies, such as when creating a cover set for a product from a single shape. However a problem I have run into repeatedly involves using "Split Solid".
The command takes a body and splits it to create 2 new bodies (body A becomes bodies B and C). This normally works good, but an annoying failure may occurr when you make subsequent shape edits (such as using a sketch with new edges to create the extrusion) upstream from the split command. When the EOP recalculates it is very likely to flip which side of the split was each solid. This then causes all downstream features to attach to the wrong body as well as making derived components connect to the wrong body.
Here's an example, I created a basic box shape by extruding a rectangle then split it horizontally to create a "Top Cover" and "Bottom Cover". If, later in the design, I decide that the shape of the box needs to be a cylinder and I change the sketched rectangle to a circle. When the split is rerun it will still split the solid but it may make what had previously been the Top Cover the bottom half and vice versa.
I've also had the same problem when I've had to create a new split surface. This forced the split to recalculate and resulted in swapping "top" and "bottom".
What I would like to see is something that either allows you to assign a body to a particular side of the split or allow you to flip the split outputs. Another option would be to have the user toggle the normal direction of the split surface.
