Show only
Search instead for
Inventor should disable all edit commands if an read-only document is opened / active. Today, Inventor only "detects" the read-only attribute when the user want to save the modified document (then the save-copy-as-dialog is displayed).
One possible implementation of this feature could be to set the the already existing DisabledCommandTypes property to kEditMaskCmdType and kFileOperationsCmdType when opening the read-only document...
