Replace a single part in a component pattern
I would like to replace a single part in a Component pattern. For example if I make a pattern of 5 Components and use copy design of element 1 and then I make a hole in the copy. Then I would like to replace the 3rd element in the pattern with the copy.
1 Comment
You could make an element "Independent." After that you can replace and constrain the one-off with the parameters from your pattern. Hope this works for you for now.
