I am suggesting a new "Repeat" function for the Assembly environment, similar to functionality found in Creo Parametric. Currently, placing multiple instances of a component (like fasteners or pins) that aren't part of a uniform pattern requires manual placement or the use of iMates, which can be time-consuming to set up.
Proposed Workflow:
- User selects a component already constrained in the assembly.
- User selects the Repeat command.
- A dialog appears listing the component's existing constraints (e.g., Mate, Flush, Insert).
- The user selects which references to keep constant and which to vary.
- The user then simply clicks the new destination geometry in the graphics window to instantly "drop" subsequent instances.
Why this is needed:
- Efficiency: Drastically reduces clicks for non-patterned repetitive placements.
- Flexibility: Allows for rapid placement where "Pattern" or "Copy" isn't applicable due to irregular spacing.
- User Experience: Streamlines the assembly process for power users who frequently work with hardware and pins.
