Remove lines from sketch block
If you have an existing sketch block then you can add lines to that block [ADD TO BLOCK]. But cannot de-add them so they will be out of the block and back in the upper sketch.
AutoCad has this functionality.
They call it: "Add to working set" and "Remove from working set"
Don’t understand why Inventor only can add lines not de-add or remove them.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
