Remove Help From Marking Menu in sketches
Remove help from the marking menu completely.  I always seem to have to close a web browser when I'm really trying to add a line.
3 Comments
mcgyvr
@jspray The marking menu is fully customizable by you the user..
Just right click anywhere in the ribbon and select "customize user commands" then go to the marking menu tab and edit as needed..
jspray
This is what I want removed.  I have customized the marking menu for Sketches, but I repeatedly hit "Help Topics..." by mistake.  Even if they reversed the Repeat feature with Help Topics it would at least keep me on the same screen.  Can I turn this line off?
As it seems, you only can customize the radial marking menu.
I agree, the general Help button is not needed in contextmenus... (especially if the help link is not related to the selection...) I think, if someone needs the help, he knows where to find (F1 is common anyway), so there is no need to stick it everywhere around...
